Old Feb 18, 2013 | 10:21 PM
onehundred80
Default Re: Remote key stopped working
Sometimes the air pump does not work because of poor contacts due to water leaking into the trunk, or sometimes the pump will work but a broken air line allows the air to leak.
If you can hear a noise from the trunk area but the car remains locked/unlocked the broken line is the cause.
Intermittent operation may be poor contacts on the pump or receiver problems.
When locking and unlocking using the key do all the locks work? If they do the pump is OK.
Give all the info you can when describing faults, problems are more easily solved when all what happens or does not happen is included in the post.
