Re: Alternator Bearings (easy replacement?)
A "chirp" is usually an indication of something in the path, like a bit of insulation hitting the rotor. Failing bearings usually have a coarsness or "rumble" to them.
Just sayin'...
But, it should be relatively easy to change the bearings-just make sure you can find them and you have a pulley/bearing puller to start with. NO PRYING!
