stryfox
Not that brave. There is a good amount of info on the forum here.
The spings are not progressive.
The srt springs are stiffer than the limited ones.
They are also stiffer than the eibach springs.
This is a good way to moderately lower the srt without sacrificing performance.
If anyone plans on doing this do a search here first. There is lots of good info to help make an educated decision.
Well, OK then. you did your homework. I just went out and bought some adjustable KW coilovers. I got my comfort, lowering, and performance in handling all-in-one. Did you get your alignment redone or are you just going with the extra negative camber? I did front MBZ camber bolts and rear camber arms after my drop. Still leaves you at -1.4 in the rear and -1.6 in front. Without those, your camber more than likely is even larger negative numbers. Accept the extra tire wear and rock on....
Some other input:
https://www.crossfireforum.org/forum...your-ride.html
https://www.crossfireforum.org/forum...no-camber.html
