Re: Fuel Filter at Fault?
Highly recommend you replace the filter.. the filter is flow/no flow issue even after half hour.... I realize there is/maybe "flow by" where the gas leaks enough through to start the car but you won't get far if that's the issue. Look into the Crankshaft Position Sensor. it's well known issue on these cars...
