Old Mar 1, 2013 | 07:45 PM
Parallel Ice's Avatar
Parallel Ice
Default Gas door torn off
Yep; you are readin' it right.
Some low life ripped my gas door off; so now I get to fix it.
The plastic assembly is still good, just the panel came off. There seems to be a caulk type of adhesive on it, but I am not sure if that is from the factory or if it is a previous fix.
Any suggestions on what to use to put the panel back on? I figured gorilla glue from HD would do the trick.
