Looking forward to getting the car out of hibernation and seeing you guys again
Long range forecast beginning March 11th and beyond looks like Spring is right around the corner. I booked the 11th off work with the plan to pull the cover off the Crossfire for the first time since December. Install the battery that's been indoors on maintenance charge, start 'er up and go from there. I'm expecting the BAS/ESP lamp to be lit up and will need re-setting. I'm not sure if the radio will remember the presets, but I'm expecting them to be there. The overinflated tires will be brought down to 33/34 psi and when everything checks out and back to normal, I'll install the LED rear license lamp assemblies purchased over the winter. Insurance is back on and with that, looking forward to another season of enjoying S.O.C.O. GTG's, meets and shows....got June 15th bookmarked!
