Originally Posted by sohc808
Hello everyone noob here. I picked up my srt-6 last saturday, and I am wondering if I can lower my car with the eibach springs and upgrade my shocks with koni adjustable. When looking on both web sites they only list the crossfire...I know the srt has stiffer spring rates so I don't know if they'll work...Any help would be very helpful...Thanks guys.
The aftermarket springs KW, H&R, EIBACH have the same preload as the OEM SRT6 springs. They may not have the same height and someone would have to do the measurements... You can remove your OEM springs and shave the upper spring pad and this will lower the car a bit. All of the aftermarket springs and dampers for the Limited will fit the SRT6. Your best bet is with the KW system even though the system is not coil-over on the rear... They are still ride height adjustable... If you can find a fully adjustable coil-over you will be able to fine tune the corner weighting of the suspension. Good Luck
