Re: help crossfire speed sensor switch
Your speed sensor should be plugged right into the top of your transmission. it has a pin that holds it in place,once you pull the pin out turn it clockwise then pull straight out and it will drop then unplug the connector and you've got it out and ready to be replaced.
