Local Mechanic in Orlando Florida Area
I took my car in today because I had a lot of problems and now I want to sell my car. Should it really cost this much? I looked at the part prices online and I'm being overcharged but need local mechanic.
1. RELAY CONTROL MODULE - PART 384 INSTALL 99.95
THERE ARE CODES IN THE COMPUTER FOR OXYGEN SENSOR, EGR CIRCUIT, AND SECONDARY AIR INJECTION PUMP THAT MAY BE RELATED TO RELAY CONTROL MODULE, BUT I AM UNABLE TO TEST FURTHER UNTIL RELAY CONTROL MODULE IS REPLACED BECAUSE THEY ARE ON THE SAME CIRCUIT.
2 WATER PUMP AND AC COMPRESSOR MAKING NOISE AND MAY CAUSE THE BELT TO COME OFF SO THEY SHOULD BE DONE TOGETHER. WATER PUMP PART 747.00 INSTALL 260.00 AC COMPRESSOR PART 1450.00 INSTALL 350.00
3. COOLANT BOTTLE LEAKING PART 82.00 INSTALL 30.00
4. AIR FILTER 69.95 INSTALL 30.00
5. SPARK PLUG REPLACEMENT PARTS 360.00 INSTALL 150.00
6. OIL AND FILTER CHANGE 85.00
7. ENGINE DECARB 139.95
8. INJECTOR FLUSH 119.95
9. VALVE COVER GASKETS AND PCV CHAMBERS LEAKING OIL PARTS 53.00 INSTALL 399.95
