Old Mar 13, 2013 | 10:44 AM
onehundred80
Default Re: Mopar Crossfire Securtiy Cargo Covers ... FOUND!!!
Originally Posted by SRT6 in MI
Hi Hi Hi!
I just came across this thread from back in December, since I am still wishing for one of these Cargo Covers myself!
Actually, my coupe HAS the mounting hardware installed, the removable cover part may be sitting in someone's garage. So just want to raise my hand and say "me too" if another chance comes up.
Also share the thought that the luggage which showed up a few months ago went through a distinct distribution channel, not the normal Mopar Accessory logistics. These covers (and Humidors, probably) were more in the normal Mopar supply chain, so less likely to go hiding unnoticed for 5+ years. Although we can still hope.
Clint
Is this Clint 'the voice'? I'm guessing it is.
It would be worth investigating if the Dodge Magnum cargo cover would fit in the bracket you have. It should be about the correct size. Even if it did not fit between the brackets, try it for length anyway to check if it will cover the trunk OK. The brackets could be moved. The assembly has a button so the end **** compresses in to fit between the brackets. The rod is 6" away from the end, but that could be moved if required.
Go to a dealer and look for a Magnum with the cover and ask to trial fit it in yours, they cost about $120 for the Magnum, 1/3 the price of the Crossfire cargo cover when you could get them.
You would be a forum hero if you found it would fit, and so would I be as it was my idea. LOL Just think your name in lights.
I did a thread on modifying the Magnum cover some time back and I always thought it could be done but I got my cover and nobody carried the torch after that.
