Thread: strange problem
Old Mar 14, 2013 | 08:59 PM
arejohn's Avatar
arejohn
Default Re: strange problem
Is it normal to be in limp mode and be able to shift manually on CFs?
I am amazed that cars can be running with a obvious defect and the CPU not throw a code. If the CPU is smart enough to put it in limp mode, it should have recognized a defect and the defect should have an obd number.
If it were me and I had no idea why the transmission was not shifting correctly, i would check fluid level and then replace that connector plug on the transmission. Oh and look for corrosion on any connectors.
