Old Mar 19, 2013 | 03:06 PM
bigblock427's Avatar
bigblock427
Default Re: Annoying sound when i open my door!!
Hello,
this noise normally appears when the headlights are on and the door is open. In you case there seems to be a fault because the sound appears even when the headlights are turned off. The sound comes from the instrument cluster (KI). There is a little beeper in there.
I think there is something wrong with your light switch, or with the harness that leads to your light switch. To check that you'll have to take a look in the workshop manual and check which cable is giving the signal from the light switch to the KI.
Hope that will help.
Regards
Markus
