Old Mar 19, 2013 | 07:00 PM
onehundred80
Default Re: Annoying sound when i open my door!!
When you turn off the lights and then turn off the ignition and open the door on my car the fog lights come on.
If you turn off the ignition and then turn off the lights the fog lights do not come on.
If you were to get out of the car after taking out the key with the lights on then the beep would sound when you open the door. when you shut the door the beeping would stop.
There must be a relay that is used to time out the fog lights and maybe it is not working properly and allows the beeper to sound instead of shutting it off in these circumstances.
I assume the fog lights do come on in your car as I mention above, it is a security feature.
