Old Mar 21, 2013 | 11:39 AM
JHM2K's Avatar
JHM2K
Default Re: Carbon Fiber Rear Diffusers
Originally Posted by Mrmiata
Got you added. And apparently shipping anything from there is not a cheap date. We may swing this to one bulk shipment and distribution state side to reduce cost, it's an option being considered.
Originally Posted by alaxfire
Good idea. The CF diffusers should stack pretty well into one package, and shouldn't weigh too much.
( I'm thinking about jumping in, haven't decided yet )
We (Nissan) do this quite often with finishers that we send to the production lines in Spain... finished parts can be nested within each other with a layer of bubble-wrap in between. As long as there is ample padding inside the box, the parcel should pass the "shake test" and there should be zero part mutilation. I'd estimate the diffusers to weigh ~1 pound per pair... so, a bulk shipment of 20 pair shipped via DHL might be a consideration. Entire container, including packaging, shouldn't exceed 50 pounds.
