Replacement of Running light inside headlight nacelle
Mar 21, 2013 | 05:50 PM
permalink
onehundred80
Apr 2006
25,432
647
Ontario
Re: Replacement of Running light inside headlight nacelle
Quote:
James1549
The "running light" term is often used in the trucking / bus industry, same as marker lights IMO. Nacelle as I recall is like an assembly, housing, or carrier(?)
In the aircraft industry
a
nacelle would have the engine in it. I believe other parts are called na
c
elles as well.
Here is what it says in the Service Manual on how to replace the bulbs, it's all done from the outside. As James says all of a ten minute job.
Quote:
REMOVAL - FRONT MARKER LAMP
1. Disconnect the negative battery cable.
2. Insert a trim stick (2) at the rear edge of the front marker
lamp lens (1), gently depress forward and lift out from the
fascia.
3. Rotate the socket counterclockwise and remove the front
marker lamp bulb from the socket.
The rear one is the same.
Quote:
REMOVAL
REAR MARKER LAMP
2. Insert a trim stick (2) at the front edge of the rear marker
lamp lens (1), gently depress rearward and lift out from the
fascia.
3. Rotate the socket counterclockwise and remove the rear
The Manual is here on the forum and anyone who has not downloaded it to their computer would be we
ll advised to do so and save time not stripping the car to repla
ce a bulb.
Sometimes the most s
imple questions are ignored as everyone assumes someone else will answer it. Guess not in this case.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
