Old Mar 21, 2013 | 06:04 PM
Buck Spunni's Avatar
Buck Spunni
Default Re: Replacement of Running light inside headlight nacelle
I think FLcrossfire is probably referring to the "eyebrow" bulbs in the top corners of the headlights, which we all know are a PITA to get at.
If you do need to get the headlamp assembly (nacelle?) out there is an easier way: pop the marker light out and look through the hole to guide your tools to the lower headlight bolts which you can access through the removeable panel in the inner fender splash guard. The upper headlamp bolt removal is obvious.
