Old Mar 21, 2013 | 06:12 PM
ala_xfire
Default Re: Replacement of Running light inside headlight nacelle
Eyebrow light removal, replacement :
Use a long 10mm combination wrench and a screw driver.
Put the open end of the wrench over the lamp socket and the screw driver through the closed end of the wrench and twist to turn the lamp socket.
Remove the lamp socket with needle nose pliers.
Replacement is the reverse of removal, except apply a little pressure on the socket into the headlight assembly before twisting into position.
Easy Peasy Japanesy
