Old Mar 22, 2013 | 11:25 PM
jamesmonter2's Avatar
jamesmonter2
Default Re: Oxygen sensor issues??? Help Please
what voltage should be at the wiring harness in order to get this sensor heater to work? I measured 10.45volts. My battery is new and is measuring 12.5v Would cutting out the end connections and directly wiring the sensor to the harness work possibly? Im thinking if there is something bad in the connection I can eliminate it. A weak point for voltage drop is always at connections. And if i shorten the wire it would give me less resistance in the wire and able to transfer more voltage to the sensor. Sound possible to work?? How do i how that the heater is working in the sensor?
