tunaglove
No that will not help. Its a simple circuit. Power goes from the RCM through the heater and up to the ecu. That's it! You either have a bad connection on one of the wires a bad heater or a cooked ecu. You need to compare your voltages to the known good sensor sitting right next to the bad one. Now do it!
I agree with Tuna here.
Find the problem first then fix it. Stay focused on it being an electrical problem.
If you just cut the connector off at the sensor you will need to make a weather tight connection to fix it or you will be right back with more problems AND there is no guarantee that it will fix your problem that you have now. Be aware that you cannot just solder the wires together either. The sensor has steel wires that are difficult to solder to.
