Infinity front speaker replacement help/advice
Mar 27, 2013 | 07:20 PM
permalink
BrianBrave
<--- Huge Horsepower
Apr 2007
3,217
So Cal
- Forum Super Sponsor -
Re: Infinity front speaker replacement help/advice
Bad speakers generally have one of four problems.
1.
burned voice coil
- smell the speaker cone near the magnet - you'll know - it's cooked so just toss...
2.
ripped surround
- look at the rubber surround the attaches the cone to the outer frame for rips and tears. If the tear is small enough, it can be repaired with flexible glue/cement.
3.
Delaminated Spider
- see if you can carefully lift the spider off the frame - if so, glue with some
loctite glue
and clamp. This picture shows a
spider that been ripped
- driver no good.
4. Broken wire from connector to voice coil - set you ohm meter to under 20 ohms and measure the resistance... if you get anyware from 1.8 - to 8.2 ohms (depending on a 2, 4 or 8 ohm driver), then wire and voice coil are fine.
BrianBrave
View Public Profile
Send a private message to BrianBrave
Find all posts by BrianBrave
