Old Mar 27, 2013 | 07:46 PM
RL67037's Avatar
RL67037
Default Spark Plug Heat Range Conversion Chart
For those interested in getting the correct heat range plug for your car, here is a handy dandy chart that might give some insight if you don't go with NGK plugs. Correct me if I am wrong, but I think the OEM heat range for our cars is a "6" if you are using NGK plugs.
I was concerned when I replaced my plugs the other day because I just picked up the Bosch plugs that AutoZone said would work in my car (an SRT). After seeing some other members questioning the heat ranges, I thought I'd see if I messed up.
The plugs that AutoZone gave me were Bosch 9603 with a heat range of 7, which compares to an NGK heat range of 6 so I think I am OK. Kind of odd, but when I go to the AutoZone web site and put in my specific car and engine, it states I should use the Bosch 9600, which is a heat range of 8. It recomends the same Bosch plug for the N/A, so I am assuming that both engines (if stock) use the same plugs.
RL
