Old Mar 28, 2013 | 10:37 PM
dom03's Avatar
dom03
Default CPS Failed? Which one do I buy?
Hi All,
I believe my CPS has failed in my limited 04 (crank but no start when i turn the key!). I did manage to get it started using a clutch start so if you are ever stuck this will work.
I need help in purchasing the right CPS module, I need to know if I am ordering the latest bosch OEM part number as I understand there have been a few releases of this part? so I want to ensure I am getting the latest revision and best brand, bosch right?
I found it available at needswings, but it is the hella OEM brand does anyone know if this is good, or should i stick with bosch?
Crank Position Sensor
and I found this on eBay, is this the right quality part? part number for this is 0261210170 < is that latest revision?
Mercedes-Benz Crankshaft Position Sensor - BOSCH - 0261210170 - NEW OEM MB Crank | eBay
