Valuable lesson
Mar 31, 2013 | 12:33 AM
permalink
JEFASOLD
Aug 2012
1,709
Re: Valuable lesson
Quote:
JHM2K
Be a dove and share the fruits of your research with us :-D
The Sherwin-Williams site lists the paint as XZA with the #62328. It's listed with each of the Xfires main colors. As far as the other things, I had some 1/4 inch aluminum tabs welded onto the bottom of the EC heat exchanger and mounted it using the stock HE holes, very solid and centered better than their method. I had to bend the upper inlet 1/4 inch to get the hose on. Also, I attacked the oil catch can problem from the other end. Using an old K&N filter, I cut a piece to cover the hole where oil splashes up into the auxillary cover and gets siphoned into the intake. The fumes can still get through but the oil collects on the filter and drops back down the hole. I used some silicon gasket material at the edges so there wasn't any loose wire, foam, etc to get in there. I haven't had this mod very long but so far it seems to work.
JEFASOLD
View Public Profile
Send a private message to JEFASOLD
Find all posts by JEFASOLD
