here you go. HTH...
https://www.crossfireforum.org/forum...ead.php?t=9469
i didn't use a spring compressor, and only have access to floor jacks and horses. ALSO, did not follow any of the service manual's directions for removing and reinstalling the spring.
FRONTS: took off the upper control arm through-bolt (accessible through the engine compartment) and rotated the entire assembly forward to remove the spring (see pic in other thread).
REARS: took the control arm bolt off (rotor side, as opposed to frame-side like is mentioned in the manual.
good luck.
