Old Mar 31, 2013 | 05:04 PM
grip grip's Avatar
grip grip
Default Re: SS brake lines: Goodridge or Stop Tech?
I hope you don't mind me posting this here, but what do you guys think of these?
MAGNUM Brakes - Performance Parts
"A large percentage of your brake pedal travel is due to expansion of the hydraulic hoses under pressure and high operating temperature. Replacing the rubber flex hoses with our stainless steel reinforced Teflon hoses eliminates this expansion and helps dissipate heat generated by braking, thus giving you a firm positive feel of your braking system. Magnum Stainless Steel Brake lines are fully covered with PVC thus give it extra protection against deterioration by environmental elements, not every brand on the market gives you this extra protection. All Magnum Stainless Steel Brake lines are tested to a pressure of 4500psi. All the hangers and holders came with our kits are made of anodized aluminum to resist corrosion. Magnum Stainless Steel Brake Lines Kit covers most of the better imports applications. All Magnum Stainless Steel brake lines kits come with a limited warranty of 2 years against defects; please contact your local dealer for details."
