Old Apr 1, 2013 | 02:37 PM
onehundred80
Default Re: A few questions regarding water pump replacement
Originally Posted by MX5racer
I'm about to change my water pump - main pump, not IC pump. There have been a few people who experienced a metallic tick sound under load at lower RMP - well water pump is the culprit. The job seems pretty straight forward: I'll remove the fan, put a cardboard behind the radiator as to not damage it. Pick up 2 gallons of coolant from Mercedes and top off with distilled water. I will outline the gasket on a piece of cardboard and insert the bolts in as I take them out as to not mix them up. I have all the necessary tools. I got a new Cardone pump for only $100. It came with a standard nylon gasket but also a rubber gasket of the same shape that's like a rubber band. Not sure what that is for? Those of you who replaced the pump please advise regarding the gasket and if anything tricky/anything I'm missing. Thanks.
Good luck, read this thread as it mentions the Cardone part and some holes that may or not be there and some that may need tapping before assembly. So check your new part with the old part to see if they are the same.
I'm not sure about the correct way to do this job but if you are draining all the coolant I would suspect that removal of the radiator would make the job much easier.
They say that you should keep all the bolts laid out in the pattern they came out in as the bolts vary in length.
