Originally Posted by Dan Root
I'll take a set. Email me. How many $$$'s and I assume you have the ducts done also?
That's great Dan!
I am actually still working on the ducts. Originally I was going to have a single molding that inserted through the access panel but there is not enough room to get it in. So I am now changing to a two-piece design; a front venturi (in the pics) that fixes to the fog light mounts with a short section of 70 mm flexi-silicone tube, then a replacement access panel with an integral vertical (100 x 30) duct that pushes into the tube and directs the air at the brake area. I will be continuing working on this next weekend. I am waiting for some costs to come back on the tubing then I can work out a cost for a complete kit of parts. I'll drop you a PM as soon as I get an answer and have worked out the GRP materials and lay-up/finishing time. Would you want them painted, primer or raw gel coat?
Cheers,
Simon.
