Old Apr 2, 2013 | 06:28 AM
ala_xfire
Default Re: issue when closing the convertible top
Originally Posted by aatln
Hi Folks,
I am on Crossfire SRT 6 for a couple of weeks now. It's an 05, graphite, 46 Tmiles, pretty good shape after some decent detailing and cleaning. Use it as a daily driver and as my 2nd car. I am really enjoying it - awesome car.
New to the forum as well. The entire forum in general was very helpful and it is amazing how much knowledge is out there.
In any event I haven't found a fix / an area to search addressing the following issue:
you close the top - everything works well (windows down, back opening, top closing) till you hear the 1st klick. Then the top window is going (fine as well) down but the final step where you hear the 2nd click afterwards before you make the final maul step is not working at all. The hook is not going into the opening or the catcher is not getting the hook.
Work around: you close the top by pressing the back center below the window just manually down till it clicks and continue /finish the closing process just as normal. No red or blinking light on the console switch after everything is done.
Any ideas where to start or to search any further.
Thanks
Aatln
As you described, the problem is in the rear bow latch. This latch is hydraulically operated, the first thing I would try is some white lithium grease on all the moving parts including the hook arm attached to the top bow. ( This fixed mine 2 years ago with this same condition, and still working fine today )
You can remove the 4 10mm nuts (#2) and drop the unit down inside the trunk for access to all the points that need lubeing :
