Old Apr 4, 2013 | 11:51 AM
RL67037's Avatar
RL67037
Default
Originally Posted by JesseJamessrt6
Thanks for the info. What about the seals for teh wing itself. Dealer item? if so how much?
There really aren't seals for the wing "feet" bit there are o-rings on the studs. My o-rings looked really good, so I reused them. The bottom of the feet have a metal insert in them that rusts, so I coated them with some spray lubricant / water repellant like WD-40 to try to keep moisture off of them. I also put a bead of the caulking rope (a very thin bead) in the bottom of the foot well to prevent moisture from getting in there. If you end up needing new o-rings, I'm sure an auto parts store would carry them. I think 180 listed the size of them somewhere on the forum.
RL
