Old Apr 5, 2013 | 12:11 PM
ala_xfire
Default Re: Crossfire won't start
Originally Posted by Mrmiata
Your a topsider oil changer aren't you!
When you pull the belly cover there is a micro switch between the frame and oil pan..that when too much torque is applied it opens the switch and ECU pulls 15 degrees of timing.. please see page 829 in the service manual...
Since I can't quite figure out if you are pulling my leg or not, and I searched my service manual for ANY mention of "case position" and found nothing, I'm just gonna go my merry way and ignore this thread.
( and I am NOT a topsider, I remove the pan and clean it and the lower engine stuff with every oil change )
