Re: SRT-6 Liftgate Leak On Spoiler Mounting Plate
JesseJamessrt6
I had some good leaks that were masked by the plastic trim. Fortunately I had it removed, saw water drips, then searched here, problems solved. I just ran a thin bead of black water proof RTV silicone around the gasket which had squished out of alignment OEM in two areas at the bottom and in one long area on the top. The studs to the wing were starting to rust. I sealed those up as well. Water was dripping from most of the nuts under this spoiler mount plate. crazy.
The trouble with this sealant is that if you do not seal it the first time you do not have a second chance.
Also any damage to this area could be tough to repair.
There is always BrianBraves solution, see post #15.
