Thread: Lug nut problem
Old Apr 8, 2013 | 07:05 PM
amx1397
Default Re: Lug nut problem
do you have ball or taper lug bolts and do you have ball or taper wheels lugs holes.first make sure they match,,
if the noise is very little, you can grind off the end of the bolt,(just don't get the lug bolts hot,(too hot to hold is too hot) .so grind a little ,go to the nex lug ,keep going around until all are ground down enough to clear.
just so you know the thd part of the lug bolt should stick through the rim 5/8" jim
