Thread: Flywheel Specs
Old Apr 10, 2013 | 12:48 PM
onehundred80
Default Re: Flywheel Specs
Originally Posted by BrandonW
So my pressure plate took a dump as my car sat in a parkinglot while I was at my kids rugby match on Saturday.
The clutch still sort of worked so I was able to limp thecar home, pulled the transmission and there it was a bad pressure plate.
Pulled the plate and clutch out and there I find a very oddflywheel.
Yes I have since learned what I can about this “wonderful”DMF but I can’t seem to find any specs for it.
My understanding is I need to check Rotational free play, and Rockbut the only spec I found in the repair manual is .003” of runout which is notwhat I’m looking for.
Does anyone know what the specs are or where I might findthem?
I don’t’ mind spending $1100 on a flywheel but to be honestwith you there are a few other parts I would prefer to spend that money on if Idon’t need a flywheel.
Thanks for any help you may have.
I doubt this is much use at the moment but just for the record ..........(click)
