Thread: Flywheel Specs
Old Apr 10, 2013 | 01:17 PM
BrandonW's Avatar
BrandonW
Default Re: Flywheel Specs
Hey Guys,
Thanks for the info and ideas.
180 I did review that before I started to pull the trany and I will tell you that step 17 was extremely helpful, as it says that step is not in the manual and it is not easy to see that pin fron under the trans. That did save me some time for sure.
I will contact Mr Mopar if I do find out that my flywheel is out of spec.
As I continued my search I was able to find something. LUK makes a tool andspec sheet for DMF, in the LUK catalog they only list a clutch for our cars but they do list a DMF for the Mercedes.
The spec for the 01-04 SLK320 DMF is 17° or 7 teeth for Rotational freeplay, and 2.9mm maximum Rock
I’m not a Crossfire to Mercedes expert but does anyone think those specsshould not also be valid for our cars?
