Old Apr 10, 2013 | 05:56 PM
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Needs ECU and Skreem module ASAP!
Originally Posted by C9ndl86
The immobiliser cuts in and alarm sounds when I'm trying to start the vehicle. Can't get any fault codes as the drb won't let me access the anti theft module(skreem) so I'm guessing the module is faulty as its receiving battery voltage. New module is pricy so only option is to source 2nd hand kit of ecu, skreem module, key and ecu- as module has to be configured to ecu and can only be done so once. Problem is I need a manual module which are rare
What are you using or going to use to program these devices together? If you have star das I think you could run drive authorization after getting your current ECU unlocked from Beckmann, that might work. They take the Immo and virginize it from any keys or VIN etc. When they would go to run or read software from the Immo they could probably tell if something is wrong with that part of the immobilizer at least. Alot cheaper than throwing money and a ton of time out for the SKREEM and ECU and such. If you dont have a way to program everything together (star das) you really couldnt do much anyway. Everything would still need to be tied to the Immobilizer and SKREEM etc...
