Old Apr 10, 2013 | 09:20 PM
rcompart's Avatar
rcompart
Default Re: Needs ECU and Skreem module ASAP!
Originally Posted by sk8erjosh09
What are you using or going to use to program these devices together? If you have star das I think you could run drive authorization after getting your current ECU unlocked from Beckmann, that might work. They take the Immo and virginize it from any keys or VIN etc. When they would go to run or read software from the Immo they could probably tell if something is wrong with that part of the immobilizer at least. Alot cheaper than throwing money and a ton of time out for the SKREEM and ECU and such. If you dont have a way to program everything together (star das) you really couldnt do much anyway. Everything would still need to be tied to the Immobilizer and SKREEM etc...
He doesn't need an unlocked ECU, he needs to replace the component that isn't letting drive authorization happen. Not trying to sound rude but there is a lot more to this than just plugging in an SDS and unless you really truly do know what is going on, you should refrain from giving advice because if you give someone the wrong advice, it'll cost them more in the long run. In his case, it may prove to be a cheaper route to replace all the components from a salvage car than buy a SKREEM and find out later that the reason it wasn't communicating was because the PSE took a dirt nap and was putting crap into the datastream which will essentially cause the same communication issues and that is a considerably more expensive module to replace than the SKREEM.
Good luck and take care
