rmaier
Evan what code are you getting for the BAS ESP light? If you are not getting a code it maybe the same problem I had with a bad speed wheel sensor. I had the darndest time figuring that 1 out last spring it took me 2 months to figure it out. I have a complete set of wheel sensors we can swap out if it comes to that.
Robert
No codes. The light is intermittent and only comes on about 75% of the time. From some of the reading that I have done this could be the cause (wheel speed sensor). The brakes seems to have a lot of fade as well. Couldn't hurt to check the pads and bleed the lines.
