Re: HELP ASAP IM STRANDED!!!! My car stalled
There were are no dealers where you are? Did Autozone tell you the codes?! It could literally be any number of things... the Code will narrow our assumptions. Could also be a MAF sensor... these are also a known problem and can cause nearly the same symptoms as you described. Once again stick with a O.E.M. or Bosch part or you'll be replacing them frequently.
