alaxfire
you are probably reffering to this diagram :
pretty much the same but different symbols. but either way i found out where those pins go.
those 2 wires power the left and right signals when the vehicle is locked. it shows it on the "EXTERIOR LIGHTS DIAGRAM" instead of the power door locks circuit. Pin 5 which is Blk/DrkGreen is the right side, Pin 2 is Blk/white is left.
so basically the the sentry key remote module grounds that relay when you lock illuminating the turn signals. Its sole purpose
