stevebeech
Need some advice on another issue. The metal rod that goes from front left wheel to right wheel ??? Is this called a steering link or is it a track rod??? and because its got slight play can i replace cheaply?? any help please.
If ts a track rod end it will be the ball joint thats worn, if so change both sides. Its a cheap and easy fix DIY, just note position on thread on sterring arm for re assembly and when done just get it tracked up to double check.
If its the anti roll bar, and if loose thats very unusual but if so will just need rubber bushes. should be a cheap fix if you get the bushes from a MB dealer as per W170. How do you know its loose, is it rattling?
