Old Apr 19, 2013 | 05:37 AM
Steve - UK's Avatar
Steve - UK
Default Re: Alarm Keeps Randomly Going Off - Please Help!!
Originally Posted by stevebeech
Glad I found this link co's mine too does it. Thought it was a common problem. Just to clarify...should i disconnect then recoonect the battery to solve it?
yes disconnect for 5 mins or so and re connect. if this dosnt work you can disconnect the siren so as not have neighbors complaining while you sort it. Drive into Halfords for a battery check as well, but I dont personally think this will be the problem as you are getting it having just driven home when battery will be well charged up. Also make sure boot and bonnet closed properly. Allso check micro switch in fuel flap not sticking (wd40)
