Re: Crossfire won't start
May be a bad engine ground. It's worth disconnecting the battery cables and tracing them to the chassis/engine and cleaning the connections just for peace of mind. You can test for any voltage between the negative cable and the engine block with a voltmeter and key in start position, and that may tell you if there is an issue there (should be close to 0 v).
I'd suspect whatever happened immediately before this issue had something to do with it.
