Old Apr 23, 2013 | 04:29 PM
oledoc2u
Default Re: Crossfire won't start
You got tires and your car wouldn't start after the tire install and no problems before this? You sure that battery has cranking amps? A battery can show charge and still not have enough cranking amps. Check connections and ground wire as mentioned above.
