Re: 2 Faults any help welcome!
Cheers for the advice re: fault 2
its funny you should mention oiling the cables because when it first happened it was only the passenger side that wasnt going up and it was really stiff. However since then the drivers side has also stopped but after oiling them both when i put them up manually they go up relatively easy.
I could understand if they werent doing anything but they do tuck in on roof closure which i find odd. Its almost like the system has said "ive had a problem with these going up so im just not going to try"
i thought about taking off the battery and resetting the system but i dont want to upset anything else like alarm etc. also does the radio have a code?
