Thread: BAS ESP Light
Old Apr 28, 2013 | 09:40 PM
oledoc2u
Default Re: BAS ESP Light
If I had a brake not working and a tire rubbing...I think I would want to look under the car. You might find something broken. Like a shock mount, spring. Does the car pull to the right or left when you apply the brakes? Check all your lug nuts (bolts)....you may even have a wheel loose... wheels shouldn't be rubbing...
