Old Apr 29, 2013 | 11:34 PM
  #1433 (permalink)
coolx's Avatar
coolx
Originally Posted by Mrmiata
And I'd guess the passenger side is slightly lit with the key on and in park... Mine weren't canbus - figured I'd live with "light out" while in reverse. Then discovered the glowing light when I left the car running with the wife inside while I ran in to pick up Pizza. Played with the 2w 100 ohm resistors (3 in a series) recommended and still no use. Hung a 25w ceramic on the passenger side and fixed the "glowing" LED. I had that one and called it good. Might get away with the 5w version.
You are correct...the passenger side light glows constantly and the light-out indicator is on. Question: a 5w resistor should eliminate the "glow"? and does the "light out" turn off?
