Old May 4, 2013 | 07:33 AM
ala_xfire
Default Re: License Plate Lights Problem -- Blown Fuse?
Originally Posted by kragath
I bought led's too and have exact the same problem. Have no dashboard light now and neither license plate light bulb does not work. I didn't have time to look for the interior fuse box today.
Is it located to same place in every model of crossfires? I have model 05' coupe v6.
Also I would like to know if there is a + and - minus sides on the bulb because I didn't see it marked on the bulb.
Thank you already!
On LHD ( US ) models it is under the cover on the end of the dash by the drivers door.
In any case, it will be the cover that has 2 coin operated latches, and does NOT have the key lock for disabling the passenger airbag.
I guess the majority that did the LED tag light update (including me ) were just plain lucky - it was just plug and play.
If yours quit and you did not do the LED upgrade, then you have a short to ground in one or both of the tag bulb assemblies.
There is no + or - on standard filament bulbs.
