Old May 4, 2013 | 10:15 AM
kragath's Avatar
kragath
Default Re: License Plate Lights Problem -- Blown Fuse?
Originally Posted by alaxfire
On LHD ( US ) models it is under the cover on the end of the dash by the drivers door.
In any case, it will be the cover that has 2 coin operated latches, and does NOT have the key lock for disabling the passenger airbag.
I guess the majority that did the LED tag light update (including me ) were just plain lucky - it was just plug and play.
If yours quit and you did not do the LED upgrade, then you have a short to ground in one or both of the tag bulb assemblies.
There is no + or - on standard filament bulbs.
Allrigth... Problem solved! Everything is running perfectly now and I didn't have to do anything to led bulbs. Thanks ALAXFIRE!
BUT... There was one thing I noticed that I should have taken picture from. The cardboard list under the cover that shows fuse numbers was incorrect. It said that license plate light should be on "hole" number 6. I checked it and it wasn't broken. Then I started to check every fuse starting from 1 and finally found the broken one from "hole" 11 (same as SMOKEY847 did).
Is this common mistake or...?
And if it is... Is there any other known mistakes on "fuse manual"?
