Old May 5, 2013 | 10:26 AM
csteve0355's Avatar
csteve0355
Default Re: Replaced H7 Bulbs Indicator On
Originally Posted by jrp758
I own a 2005 Chrysler Crossfire. I recently had to replace a headlight bulb. I decided to replace all H7 bulbs and the foglight bulbs. With Sylvania HZ ZXE bulbs and 9006xs Sylvania ZXE bulbs. However everytime i turn on the headlamp low beam bulbs on the dashboard instrument panel light out indicator appears. These bulbs should be the correct replacement. Is there any reason as to why this indicator will keep coming on only when I turn the bulbs on?
Any help is appreciated. This site has been great.
I assume you checked that both low beam and high beam bulbs are lit.
I replaced all my H7 with the Sylvania Ultras and have no problem with the light out indicator.
Check around the car to see if another bulb is not lit.
