Old May 5, 2013 | 10:45 AM
onehundred80
Default Re: Headlight Bulb Replaced Indicator Light Goes On
Originally Posted by jrp758
I own a 2005 Chrysler Crossfire. I recently had to replace a headlight bulb. I decided to replace all H7 bulbs and the foglight bulbs. With Sylvania HZ ZXE bulbs and 9006xs Sylvania ZXE bulbs. However everytime i turn on the headlamp low beam bulbs on the dashboard instrument panel light out indicator appears. These bulbs should be the correct replacement. Is there any reason as to why this indicator will keep coming on only when I turn the bulbs on?
Welcome to the forum.
You started two threads and this always splits the answers into two and gets confusing. Also there is a forum for exterior and lighting and it would be best to use that.
